E-Class (W123) 1976-1986: 240D, 280E, 300D, 300TD, 300CD
Glowplug light stays on
Old Feb 15, 2009 | 07:49 PM
ClearDark's Avatar
1983 Mercedes Benz 300D
Hello all,
Glowplugs appear to be working fine, however the light stays on when the car is started/running.
What is the main cause of the light staying on?
Thanks.
Old Feb 16, 2009 | 07:47 PM
johnjzjz's Avatar
E420
the glow box has a board i believe and my guess a diod is leaking to ground and that will turn on a light - i would put a test light onto the glow plugs and make sure they turn off - jz
Old Feb 17, 2009 | 04:27 PM
KDools's Avatar
1982 240d
I had the same issue with my 240d. The light would stay on-and so would the glow plugs. This was draining the battery slowly. The alternator was working fine but the glow plugs were draining the system faster than the Alt could replenish the battery. I had a bad glow plug relay that was not turning the glow plugs off. I picked up a bosch glow plug and relay set for about $105 and all is working well now.
Kevin
