Ok, seriously, help?
To update, I replaced the water pump this morning. Everything seemed fine except my fan/pump/alternator belt was really loose. When everything was done I took her out for a spin, and the temp rose slowly to normal, hung there for a couple minutes, then began to rise right back up, almost to where it was before. The problem seems slightly better, and the leak is gone, but why is it still running hot?! This is driving me crazy! Please help!
Could be the Raidator is becomming restricted either inside or maybe the exterior fins have become full of dirt blocking the Air from going throuh the Radiator.
My last though is that you could have a small Head Gasket leak that is causing gas pockets inside of the Cylinder Head. This would cause local overheating.
You could also consult a regular Motors or Chilton type manual for the normal problems that would happen on any cars Coolant system.
If you have an Auto Trans besure there is enogh Fluid in that as the Trasns Oil is cooled in the Radiator; if it is too hot the Radiator has to try to get rid of that heat also.
A good fan clutch will have a heavier resistance when trying to turn it by hand and a bad or going bad clutch will be easier if not free spinning by hand.
Please dont take this verbatim, but it was the trick with Chevy, Dodge and Jeeps....
It's a fairly cheap part compared to a head gasket, plus, you're pretty much ruled that out anyway.
I will consult a Ford Master Tech on the 12th to confirm the clutch wear idea....
If it is bad or going bad, it will spin with little resistance. If it is really bad, it may have leaked an oily substance out near the spring....He also said if the car starts running hotter than usual with no other issues( radiator, water pump, old coolant) it will more than likely be the fan clutch.
