E-Class (W123) 1976-1986: 240D, 280E, 300D, 300TD, 300CD
300CD let me know if these are good quotes for repair work!?! Thanks!!!
Old May 7, 2012 | 02:33 PM
MadeToDefend's Avatar
300cd
Just bought a 1985 300CD-T let me know if these are good quotes for repair work!?! These are just the prices for the parts I believe. Let me know what I should expect for labor and if these prices are ok... Thanks!!!
- Evacuate and charge A/C system - $231.00
- Remove and replace vacuum modulator on transmission - $201.15
- Remove and replace value cover gasket - $119.80
- Remove and replace shifter bushings - $82.40
- Remove and replace diesel filter - $97.88
- Remove and replace all belts - $146.11
Thanks all!
Old May 16, 2012 | 08:05 AM
Whargoul's Avatar
1985 300DT
Extremely expensive and a waste of time. It should cost under $150 even if you stick with R12 refrigerant.
If it holds refrigerant and works, don't screw with it.
If it leaks, recharging it will not fix the leak and you'll just blow more money on it next year.
EXTREMELY expensive.
And its much more likely you just have a vacuum leak from a valve on the top of the engine.
A new modulator is $35, takes 15 minutes to change and 30 minutes to adjust correctly.
OBSCENELY expensive.
A valve cover gasket costs $7 and takes 15 minutes to replace.
On top of that, replacing the gasket without doing a valve adjustment is a waste of time.
The bushings are $2 each and take 15 minutes to replace.
10 if they do it the same time as the modulator.
OBSCENELY AND STUPIDLY expensive.
The filter is $12 and takes 10 minutes to replace.
This one is somewhat reasonable. New belts will cost about $50 for decent ones and adjusting them can be difficult.
Other than the belts, I'd say that shop is trying to screw you without using any lube.
What they are doing is trying to scare you away with extremely high quotes. They don't want to work on old cars, and if you make them do it they will make a very good profit.
So, find an honest shop that actually wants to earn money.
