E-Class (W123) 1976-1986: 240D, 280E, 300D, 300TD, 300CD
Oil breather fitting
Old Oct 21, 2014 | 01:17 PM
Gshep71's Avatar
1976 240D, 1985 500SEL
I have a 1976 Mercedes 240D with the standard 4 cyl diesel. The oil breather fitting on the valve cover has been missing for some time. This is a problem for obvious reasons - I loose quite a lot of oil and it makes a mess.
Where can I find this part? I've looked almost everywhere, even checked the junk yards.
Thank you!
EDIT: the fitting that was in there was brass, and threaded. NOT a plastic or rubber piece.
Old Oct 21, 2014 | 01:34 PM
ECSTuning's Avatar
Former Vendor of MBWorld
2012 SLS AMG
Gshep71,
From what I am able to find, the fitting you are looking for is no longer available through Mercedes-Benz. I can provide you with the part number you are looking for to help your search. The part number is A 615 997 00 72. I hope this information is able to help you find one for your vehicle.
If there is anything else I can help you with please let me know.
David
