Diesel Injection Pump timing
(you can NOT use the "bubble" method, it does NOT work)
Set the engine to 24-26*BTDC and install the pump.
You can engine-stand time it with a fuel container.
Pump the primer 30 times after you hear the relief valve vent to evacuate air from the pump (about 60 pumps in total).
Tie the throttle lever to MAXIMUM.
Remove the #1 delivery valve from it's holder.
Move the pump until fuel spills freely from the drip tube then move the pump back until you get 1 drop per second from the tube.
The pump must be installed AFTER the timing chain has been installed onto the crankshaft and timing device sprockets.
