1983 300TD SLS
1983 300TD SLS
I'm looking for a detailed diagram of SLS pump to 617.952.
My motor had pump removed by PO and orifice covered with billet plate.
I would like to restore but in meantime after removal of delete plate I see a driver key that interfaces with mounted pump and one bolt at the top with flange that sits on a ring around driver.
Below is another hole that is diagonal to bolt but is empty.
Not sure if this is meant to have another bolt holding whatever's inside or possibly to hold other side of ring or an oiling hole.
Can anybody help with this.
Even a verification of what the state is supposed to be once pump is removed from motor.
Thank You.
Thank You.
