240D Accelerator Pedal - is this normal?
I am looking at an '83 240D (manual) and it seems to take about 2/3 of the gas pedal travel just to give enough throttle to leave a stop. It's like dead space for the first half pedal. This doesn't seem normal, despite what the owner says. It seems to do okay (albeit slow) with the throttle buried into the floor. Could this just be a linkage adjustment?
Also, besides the oil cap blow-by test- any other quick engine health assessments I can make before purchasing? It had been sitting so it took a little cranking, but very minimal smoke.
Thank you!!
Thank you!!
I don't mind turning a wrench a bit, but am deathly afraid of some high dollar item being the culprit such as the fuel pump or something. I'm actually excited to learn about the vacuum system and was super impressed by the build quality of these w123s. The engine seems to shake lot, but there's no leaking and very little smoke. Smoothed out nicely once warm and quits instantly once I shut off the key too. Now I just wish I had more time for a project
IRT shaking, one of the most commonly ignored (by the uninitiated) maintenance items on our engines is the valve adjustment. It is fairly easy to do about every 10 to 15k miles and will leave you with a much smoother idle and a great feeling of accomplishment. Other common sources of rough idle can be air in the fuel system, dirty fuel (look at your clear plastic primary filter) and rarely bad injector nozzles. I say rarely because injectors should go about 100k miles without need for rebuilding.
These are great engines and dead nuts easy to work on.
