w123 300d oil filter
For the life of me I can't find the oil filter housing, nor the appropriate oil filter.
The closest thing I can see to an oil filter is in the third image, plumbing off the oil cooler.
Andrew Howe (09-23-2019)
It's definitely a w123 chassis. I wouldn't put it past being an older engine. The front of the block says 617 016 03 04 below that there's a 75 if that helps. Also the third picture is below the fuel filter next to the drivers side wheel well.
W123 300CD, R107 560SL, W211 E320
If so, your oil filter canister is under the engine. Get down and look. A change consists of removing the center bolt and letting the hot oil run across your chest and into your armpit.
