1979 300D High Beam / Fog Light Issue
For the most part everything is in order except the high beams.
When I engage them the low beams dim and the FOG lights come on.
I am guessing either the headlight switch or high beam switch is faulty.
Looking for diagnostic tips to determine which it may be.
Some diagrams I've found show a brown wire to ground off of post 31 on the headlight switch.
I have no such wire.
Also my headlight are the 6 pin Euro instead of the 4 pin US wiring
Would this make a difference in the headlight switch wiring?
cleaned the fuse connections
Replaced both switches
with no success.
The wiring must be butchered somewhere.
Gonna start in the lights and move towards the dash with a test light, multi meter and a fine toothed comb.
1 tip is used to use was some door bell bell wire... very cheap by the roll, long and stiff, ... good to check a long run... aka completely disconnect switch and light and then use the bell wire to connect direct from switch to the lights... the stiffness helps with being to bend and wrap around stuff with out it hanging everywhere....
apparently at some point someone took apart the LS (driver in US) head light connector
The high beam and low beam were crossed.
One would think it does not matter but it resulted in the original symptoms.
So $150 in switches for naught.
Live and learn.
now you got some extra switches
