E-Class (W123) 1976-1986: 240D, 280E, 300D, 300TD, 300CD
W213 Spare Tire
Old Nov 17, 2020 | 05:19 PM
Drakonian_Fury's Avatar
W213 E300
W213 Spare Tire
Hi All
I have seen this top discussed differently so decided to write a fresh thread.
I have a US spec E300 4matic with 245/45 R18 tires.
I am looking to purchase 213-400-06-00 which has a spec of 135/70 R19
Want to get rid of no warranty 20K run flats with warranty included 50K continentals
I found that the tire diameter is very close (spare is 0.24mm smaller). attaching an image for stats
1) Is this substantial enough to through the 4matic off?
2) If i can use it, hoping someone else has, do the same lug nuts fit?
I do not mind loosing the trunk space!
Thanks All in advance
Old Nov 18, 2020 | 06:53 PM
S70Houston's Avatar
2018 GLC300 4Matic; 2008 ML550 4Matic; 2004 C320
You are posting in the W123 section, NOT in the W213 part of the forum.
You may try posting there to get the correct answer.
