E-Class (W123) 1976-1986: 240D, 280E, 300D, 300TD, 300CD
issues getting my W123 moving from a standstill
Old Oct 20, 2024 | 01:42 PM
300dt's Avatar
1984 300D TurboDiesel, 2001 S500
I've got a 1984 300D Turbo Diesel with 380K miles on it. The other day I was driving it and came to a stop. When I took my foot off the brakes there was no forward motion as usual. When I pressed the accelerator, the engine rev'd but the car did not move forward. I gave it a few more revs and eventually it started moving slowly until 1st engaged and it shifted fine to 2nd-3rd & 4th gear as normal. Next time I stopped. The same thing happened. Did it every time I stopped until I got home. checked trans fluid level. Was about 1 pint low. Topped it up then took it for a spin in the neighborhood, same thing. Reverse gear works fine. When I go from park to drive, there is no longer the familiar thunk and engagement of the transmission. As all the other gears are working fine is there something specific to 1st gear only?
Old Dec 13, 2024 | 10:12 AM
OM617.95's Avatar
1982 300D
Bad transmission. Its a common failure and not DIY fixable.
Old Dec 17, 2024 | 12:36 PM
Heavenseyes's Avatar
1984 300D
Transmissions aplenty
You shouldn’t have any problem at all finding an transmission for this car, lots of cars out there.
