E-Class (W123) 1976-1986: 240D, 280E, 300D, 300TD, 300CD
fuel system
Old Mar 25, 2026 | 09:58 PM
mozell's Avatar
fuel system
I have a 81 240d. I was about to replace my injectors because of rough idle and low power. I started the car before I started the repair and it ran rough. It usually does. I disconnected the fuel line to one injector and found I had no socket that fit the injector. so I reconnected the line and the return hose, thinking I would find the correct socket and continue. I immediately tried to start it again. Wouldn't start. Disconnecting and reconnecting the fuel line was all I did. I checked and fuel is getting to the injectors. Cranked and used glow plugs. Won't start. What did I do?
Old Mar 26, 2026 | 03:29 AM
ygmn's Avatar
2015 E400 Sedan
air in line?
Old Mar 26, 2026 | 09:44 AM
streborx's Avatar
Top Answer: 1
G550
Deisels are finicky with fuel lines, and it likely needs to be purged of air. If you have a service manual, there should be a procedure for how to do this. Or maybe a YT video.
