interior lighting problem
My interior lights fail to come on only when the driver door is opened. The interior lights come on as they should when all other doors are opened. I think I have identified the problem to the wiring that goes from the Springloaded door switch on the drivers door to the actual lights. I know that the switch itself is o.k. because I have swapped it with the passanger side and it works. There are two wires that plug into this switch. Does anybody know how to access them or where they go(I assume they go to the overhead light through the front A pillar)It looks like you may be able to get to them through the lower side of the drivers foot well, near the emergency brake pedal, but you may have to remove the front quarter panel. Anybody know? Thanks, Matt.
