How to check CEL on a 95 E420?
One port has an 8 hole pin out with a small button and a light. The 8 holes do not fit the actron obd2 scanner, the are aligned in a straight line.
The other looks like a Formula wire harness connector, it's circular not 8 pronged like the normal OBD2 connectors I've seen. However, this one is located near the ECU (which in located in this battery looking thing under the hood).
Anyhow, my question is how do I check my CEL? I'd like to check my code for free instead of paying a stealership. I've asked this question in the other forum and they said it wasn't OBD2, which I do believe, since all OBD2's are generally post 96, but are those two ports the only routes of pulling the code?
Thanks.
http://pages.prodigy.net/jforgione/MB_S500.html
AshMan
