Lights on the Gear Shifter not woking
1995 S320 and 1995 S500
The light on the Shifter is not working, the one with P R D etc on the console. How does one fix this?
Mercedes E220 cdi
Remove the wood trim around the shifter and you will get access to a press-in/clip-on bulb located at the front of the shifter housing. Pull it out and replace bulb and assemble everything again.
