Head Rest question
Old Jun 8, 2005 | 02:51 PM
Brian Felts's Avatar
E 320
Head Rest question
I went to use my head rest button on the door and the head rest would not move. I could move it with my hands and I can hear the motor running in the seat. How can I trouble shoot this?
Brian Felts
Old Jun 8, 2005 | 06:02 PM
AMG_Fred's Avatar
Mercedes-Benz w124
same here. i think i need this
http://performanceproducts.com/Produ...Switch&type=40
thats what my dad told me. im skeptical though. i have the exact same problem on both seats. and it also feels that my seat is loose. the back of the seat ( where i lay my back on ) can be moved back and forward :\
Old Jun 8, 2005 | 07:17 PM
ashman's Avatar
2004 C240, 2015 GL350 Bluetec
most likely there is some broken plastic inside the seat that holds the headrest.... common problem.
you have to remove the seat back...
AshMan
Old Jun 8, 2005 | 08:39 PM
Kestas's Avatar
95 E320 Cabriolet, 108K
I agree with ashman. They were $16.50 apiece when I replaced mine 2 years ago. If you really want to go cheap, you can fix the broken part by clamping it together with a hose clamp.
Old Jun 8, 2005 | 09:31 PM
AMG_Fred's Avatar
Mercedes-Benz w124
at the dealership? did you do it yourself? if not, then who did it? i want to fix this
Old Jun 9, 2005 | 07:50 AM
E 320
Thanks all I will get into it this evening or tomorrow. I have power because I can hear the motor run. I am glad its a easy fix. I never use them but the fact that something does not work.
Brian Felts
Old Jun 9, 2005 | 10:12 AM
Kestas's Avatar
I did the repair myself. The most difficult part of the job is removing the seat back. There are two screws at the bottom of the panel. Once those are removed, start from the bottom and pry up on the lip that is tucked into the channel, working your way up to the top. You don't necessarily have to do the other side, though it's easy once the tension is released. Once the back is off the problem should present itself.
Old Jun 9, 2005 | 11:26 AM
AMG_Fred's Avatar
Mercedes-Benz w124
brian, can you post pictures of your progress and them post them up here? that would be a great help.
