Correct tire PSI?
let's do this. you find me at lest 10 manus in the 1990's that recommended pressures beyond 32 psi and i will gladly call it a day. because after all this is a discussion about cars built in 1993 and 1994 not 2005.
You know, someone else already answered this beautfully but since you seem fixated on 32 PSI, I'll paraphrase it. 32 PSI is not a fixed standard; it's a rough average starting point for passenger automobiles. The year of the cars doesn't matter. 32 PSI gets you in the ballpark.
Regarding answering my two questions, it turns out I was right. Eric, you didn't answer either question; you simply responded to one with vague statements and the other was a complete non-answer. How about if I put these questions to someone else? Anyone else care to take a crack at it?
most trucks and SUVs sold today come with passenger tires, tires designed to be quiet and smooth. much like a car tire. these tires typically have a max inflation of 35 psi. some have 44.
a few trucks, notably those of 3/4 ton designation and higher, those with towing packages and some with off road packages, come with LT tires; tires designed for towing and hauling. these tires will have max inflation ranging from 44, 50, 65, 80 etc. notice the higher pressure for tires designed for carrying loads?
if you buy a truck with passenger tires, and decide to buy a boat, then by all means, get the LT designated tires, and increase the air pressure.
i could use the analogy that if you have an engine with a 7000rpm redline and you run the engine less than that then you are not running it as intended. is that the case? no? if 7000rpm, is the maximum, then 80psi is the maximum as well.
what were you saying about my critical thinking?
all the R129 SLs had z rated tires, including the 300SL which had the same engine as your car.
all the 500Es had them.
i believe the W140 600SELs had them too though i could be wrong about that one. all those cars were sold in that period.
if i have a car that has V rated tires (149mph maximum) then i could conceivably go 150 on them for a short time without them overheating and blowing up.
and ps, i never said anything about my car going 150.
you clearly didnt look thoroughly at the page you linked to, nor read its contents. (without looking it up) this is how you decode the top line;
31/10.5-15C tire size
109T service indicator; load and speed rating.
BSW denotes black sidewall
34176 michelin part #. bf goodrich is a subsidiary of michelin
438-895 stock number
7.0- 9.0 rim width range
10.8 on 8.5 width of tire on specified width rim
30.8 height of tire
18 tread depth in .32 of an inch
675 revolutions per mile
2250@ 50 maximum load capacity in pounds at listed MAXIMUM inflation pressure
yes, i have sold tires before. i know more about them than you do.
this is the fun part.
located in the legal info, the small print at the bottom of the page is this little disclaimer
there it is. nuff said.
, the reason your tires "cup" is because i can think of at least 6 manufacturers who had psi of 35 or higher on some of their cars in the early 90s
GM (buick, pontiac, chevrolet, cadillac, oldsmobile, GMC) does that count as six?
ford (lincoln, mercury)
chrysler (jeep, dodge)
porsche
volvo
ferrari
land rover
and thats off the top of my head. im thinking lotus and lamborghini should be on that list but i dont remember, its been a long time since i worked on one. i could probably make some calls and find three more tomorrow to complete the list, but thats too much trouble. besides, its more fun to come here and debunk almost everything you say
i'll say it again; yes i have sold tires before. yes i do know more about them than you do.
no
, the reason your tires "cup" is because.... cupping refers to the wavy forms that showup on a tire when a tire has not been rotated or has been run on a car which needs suspension work. refer to this page and this one for a clear and consice depiction of cupping and pictures.
I think you should let AMG_Eric off the hook. His car looks too good for him to be an idiot or a jerk. It is OK if he likes to ride with very hard tires.
btw this is what i call cupping
now maybe i am using the wrong terminology because i never sold tires. however that is what my tires did.
a 195/65-15 tire inflated at 26psi will have load capacity of 1045lbs.
a 215/45-17 tire will have that same load capacity at 29psi.
IIRC our cars are recommended to be inflated to 26F 29R (certain years.) this means the 32psi AMG was advised to inflated his tires to was correct, and the tire guys were NOT goofs or whatever he called them.
most shops will inflate front and rear tires to the same psi. most people dont notice the difference.
that pic is for a severly underinflated tire. as in 20psi or less. low enough to where you can see the tire is underinflated. not valid in this discussion as 32psi is adequate.
: !!! YOU THINK YOU HAVE ALL THE ANSWER FOR F$%CKEN A MERCEDES AND YOUR NOT A MECHANIC
! ALSO WEDSTER, NEANDERTHAL, AND MTI ARE NOT THE ONLY ONES TRYING TO GET SOME SENSE IN YOUR HEAD
SORRY I DON'T NEED TO CALL A BUDDY OR GOOGLE SEARCH TO FIND ANSWERS!! LOL PROBABLY YOU SENT YOUR CAR TO A MECHANIC TO PAINT YOUR CALIPERS!
THE PROBLEM IS YOU NON-ANSWERS AND MIS-INFORMATION TO OTHER FELLOW MB OWNERS! WHY YOU GET MAD WHEN SOMEONE ELSE HAS THE RIGHT ANSWER DAMN!!
ACTUALLY AMG_ERIC MADE IT SUCK!
as far as the brake post if you talk to a pro that builds race cars for a living you will learn something as i have instead of taking off the cuff know it all comments from a guy that was even referring to the cars we drive. but hey off topic time is over.
I didn't have anything against you until i saw you posting all kind of Bull***** for people who know 0 to nothing about car and telling them that your right about it because you have a race team pro buddy who you asked!!
Yes i had a POS at the time but it's a process of upgrading one thing at a time! why am i going to say i have the best this and that UNLIKE YOURSELF! I love mbz but i am true hotrodder and do the work on my car MYSELF! I even went to the meet with a broken ball joint on the centerlink without a sweet because the next day i installed a new draglink, steering shock, ball joints, and got new beilstein shocks! Guess what i did it all my self except to the aligment.
Stop trying to be so damn right all the time and learn things on the forums LIKE WE ALL HAVE!!!
