locking doors...
So, did you know......
Holding the key in the lock position closes all the windows and sunroof.
Holding the key in the unlock position afterwards opens all the windows.
Turning the key all the way clockwise when locking the boot isolates it from the central locking.
When the boot is open pulling the switch turns off the boot light (later models only, I think).
Turning the trip reset dims the dash lights.
It's possible to check the computer's fault codes using an LED and some wire (handy for fault finding, later models only)
With the engine running and the car stopped, putting the gear lever into '2' then back to 'D' forces the box to start in first gear.
I was wondering if any of you know if it is possible to hook up a keyless system on these cars. I took it to an alarm place and they wouldn't do it being an MB so I was just wondering if anyone here has done it.
Also, any tricks to getting the locking feature to work from the passenger side? I can lock and unlock all doors from the driver's side but not the passenger's side.
As an aside, the closing/opening windows/sunroof trick doesn't work on my '92. I know it works on the w211 and the w208.
I don't think any of these cars allows you to lock/unlock the doors from the passenger side...only the drivers side and the trunk.
My car ('95) allows me to roll up/down the windows and close the sunroof using the key.
I dont know cant try them my cars at the Dealership atm -_-
