300E engine mounts - need advice
Old Aug 26, 2005 | 08:02 PM
benzdriver737's Avatar
W167 GLE 400d 2019
After reading so many posts regarding 300E engine mounts, I've decided to replace mine. (1989) What I need to know is: what tools are required and in what sequence should I approach this job. Any little things to beware of or avoid.??. Is this something that an average DIY person should attempt.?.
Let me know if it is something I should leave for my local Stealership to fix.??
regards
Old Aug 31, 2005 | 01:15 PM
AMGDave's Avatar
300D, 500E, E420
It's not too hard... should just need basic hand tools, plus an 8mm Allen wrench or socket. The driver side top bolt is a pain. Do one side at a time and don't rush the job. Shouldn't be a problem as a DIY, no need for the stealer to do this. Check the mount at the rear of the transmission too...
Old Sep 2, 2005 | 10:53 PM
MBHustla858's Avatar
tranny mounts do go out as often as motor mounts
