POWER LOCKS! not working
1995 S320 and 1995 S500
I took my car to the shop to get it alligned and when I picked it up the power locks stop working! What to do????? Please help
Gman
Gman
Do you know which fuses???? the diagram in the car does not say???? I checked all fuses.. all seem to be ok!
HELP!
THANKS
HELP!
THANKS
1992 300e
Well I checked on my service manual cd for you. For the central locking system it is saying "Fuse C", which I have no idea about lettered fuses. It is on the same circuit as the power antenna and the trunk lamp. So if your antenna and trunk light work, the fuse is fine.
Maybe someone else might know about fuses with letters, not numbers.
HTH,
Ron
HTH,
Ron
Is fuse C under the hood near the winshield. All those seem to be numbered. It is too dark where I live to chaeck at the moment. However at first light, I will look.
Gman
Gman
1992 300e
That is just it, I Don't know where it's located The fuse diagram I have shows the Numbered fuses and the relays. Not fuses with Letters. Did you see if your power antenna ans trunk light are working? They are using the same fuse, so if they work the fuse is fine.
Aren't the locks "powered" by vacuum and not electric motors anyways??
Ron
Ron
