HELP! M104 missing on acceleration
Old Oct 23, 2005 | 12:56 AM
upsidedown_04's Avatar
'93 300E 3.2, 55 Buick Super, 68 Dodge Dart, 65 BSA A65
Hi .. I have a '93 with an M104. Its been running great until this week. Here are the symptoms:
Idles great.. smooth as silk in gear or neutral.
Up to quarter throttle it is good but if I go past that it starts to backfire and miss and runs really rough. I've read here about the bad engine harness but seems to have to do with throttle position or RPM. Any help would be greatly appreciated!!!
THanks,
Carl
Old Oct 23, 2005 | 01:42 AM
YNVDIZW124's Avatar
lots of cars
Any codes?
Old Oct 23, 2005 | 02:34 AM
TheDoughboy's Avatar
1992 300e
A bad coil or ignition module can cut out at rpm, causing misfire & backfires. Most of the time this will happen under a Load, not just revving it up in neutral.
HTH,
Ron
Old Oct 23, 2005 | 12:33 PM
Help
Thanks for the replies.. no there are no trouble codes.. LED just flashes once.. I thought about the coils too but seems to really have something to do with throttle position.even in neutral in the driveway .. if I push the throttle past the 1/4 mark it will act up .. . read a little about the TBA but seems most have problems with the cruise control ... are there any other signs of the TBA going bad?.. could it be the the engine harness?.. is there a way to test the coils other than replacing them?.. sorry so many questions.. this is my first Mercedes .. My wife loves this car.. I did until this week.. starting to get frustrated!!..
Old Oct 23, 2005 | 01:22 PM
Coils
Is there a way to OHM out the coils or some other sort of test for them?.. starting to explore that Doughboy.. thanks...
Old Oct 23, 2005 | 04:44 PM
Harness
Look familiar to anyone?.. Looks like my harness is shot.. would that be the culprit?
Old Oct 24, 2005 | 12:20 PM
ashman's Avatar
2004 C240, 2015 GL350 Bluetec
that doesn't look good...
If the harness has not been replaced and your car is a 93 - 95 model, then definately do it.
Install is not difficult... there is a DIY article on Mercedesshop in the DIY section on doing it.
Is that part of the main harness or just a small section?
Old Oct 24, 2005 | 03:18 PM
I believe its part of the main harness.. its the wires that go to the coils under the removable sevice plate on the valve cover. Yea from what Ive been reading that its a common thing for my year.. yeesh and dang expensive!!.. is there any where thats cheeper than another?.. any advice on where to get this bugger??
Old Oct 28, 2005 | 02:43 PM
ofer's Avatar
300TE
Advise & codes reading?
check also the fuel pressure at high rpm (around 3000)
if its appear only at high R.P.M in N position also it can be a blocked CAT
How can i read the codes from the 8 pin connector? i built a led with a resistor, but i don't know the steps to read that codes on pin nr.3
Old Oct 29, 2005 | 05:21 AM
cap'n jasper's Avatar
W124
Change that harness ASAP. It's not uncommon for a bad harness to blow the coils or ECU (big$$$). It's mid nineties Mercedes cost cutting at it's finest. (Although Mercedes will claim it's biodegradable and designed like that!). Do a search for wiring harness and you'll have plenty of bedtime reading)
Old Oct 29, 2005 | 10:11 AM
Thanks Capt'n.. Im going to order one this week... any idea where's the best place to get one? my part number is 124 440 8308
Old Oct 29, 2005 | 01:40 PM
W124
Can't help you with where to buy one (I'm in the UK) but here is the article referred to earlier on how to do it
http://www.mercedesshop.com/Wikka/M104WireHarness
Old Oct 30, 2005 | 10:16 AM
Sorry.. didnt check your profile before.. hey can I order a 1/4lb Honolulu Burger sent to California?.. My wife wants to visit England next year.. art, history,culture,Big Ben.. blah blah blah.. but now a good burger! .. I could go for one of those!
Thanks for the link .. Im wondering now if the main harness is so bad, I wonder if the throtle actuator is also just as bad... should plan on that one too..
