Oxygen Sensor Install
Old Nov 1, 2005 | 01:49 PM
NorCal124's Avatar
W124
I recently did the O2 sensor install on my 124. I actually did the install suggested by jrmd01 where you take the O2 sensor from another vehicle and splice it into the connectors of the OEM sensor. The other reason I did this is because Chris isn't smart enough to do this himself and he needs someone to hold his hand and show his sorry @$$ this simple task. j/p
What you will need:
- Wire splicer
- Soldering rod/gun
- Sodder
- Heat shrink or electrical tape
- Adjustable wrench
- Small flathead screwdriver
- Oxygen sensor (Bosch p/n - 13953)
Here are some comparison pics of each sensor before I go into the step by step instruction.
Attached Thumbnails Oxygen Sensor Install-109_0907.jpg   Oxygen Sensor Install-109_0914.jpg   Oxygen Sensor Install-109_0915.jpg
Old Nov 1, 2005 | 01:53 PM
NorCal124's Avatar
W124
1. First disconnect the sensor plugs located under the passenger side carpet.
Attached Thumbnails Oxygen Sensor Install-109_0908.jpg   Oxygen Sensor Install-109_0911.jpg
Old Nov 1, 2005 | 02:00 PM
NorCal124's Avatar
W124
2. Next, lift the car from the left side using a floor jack and jack stands (it was easier for me to use two jack stands). Once lifted locate the O2 sensor positioned about one foot back from the transmission oil pan. Remove the heat shroud that clips over the sensor and then undo the O2 sensor using an adjustable wrench. I found it easier to remove the sensor by pulling through the rubber grommet and connector from inside the compartment.
Attached Thumbnails Oxygen Sensor Install-109_0912.jpg   Oxygen Sensor Install-109_0913.jpg
Old Nov 1, 2005 | 02:09 PM
NorCal124's Avatar
W124
3. With the sensor removed you can begin to splice in the new sensor. When splicing the connector into the new sensor be sure to note which wires are which. I differentiated the wires by their positions to the left or right of the black wire using tape to indicate their location (do this on both sensors before cutting). Once that is complete cut and splice each wire one at a time. Slide the heat shrink over the spliced wire prior to soldering them together. Do this on the two remaining wires. As a precautionary measure you can further wrap the wire in electrical tape.
* PLS. NOTE: The pictured splice near the connectors is a second splice I made because the wire was too long and I wished to shorten it.
Attached Thumbnails Oxygen Sensor Install-109_0921.jpg   Oxygen Sensor Install-109_0920.jpg
Old Nov 1, 2005 | 02:13 PM
NorCal124's Avatar
W124
4. Lastly, install by reversing the removal process and attach the connectors. It is also easier to re-insert the grommet using a small flathead screwdriver. After that you're done.
Old Nov 1, 2005 | 02:42 PM
CDP's Avatar
CDP
W124's
What can I say, you love me so that's why you do such nice things for me. Thanks for the write up, I'm sure everyone else will find this helpful besides me.
Old Nov 2, 2005 | 08:42 AM
shadowgriffen's Avatar
is a German Tank
excellent!
great write-up norcal
Old Nov 2, 2005 | 11:59 AM
Kestas's Avatar
95 E320 Cabriolet, 108K
Good write up. Let me add a few comments.
Sometimes it's better to stagger the splices. That way you don't get this pregnant mass of wire bundle in one spot when threading it through the hole.
I have yet to buy a socket for O2 sensor removal. I've always gotten by threading the pig tail wiring through a box-end wrench, which gives more purchase than an open-end wrench.
Old Nov 2, 2005 | 12:41 PM
NorCal124's Avatar
W124
You won't need a socket to remove the O2 sensor on W124s because its not situated in an ackward position like on an exhaust manifold. You can use a simple adjustable wrench for this one.
Old Nov 2, 2005 | 03:57 PM
Nick_M_51988's Avatar
1992 400E (86 300E, 98 S420) - Retired
thanks alot. i just went to the stealer and got a quote for a o2 sensor. it scared me.
i think i'll head to kragen this weekend and pick up a sensor. my gas milage is like 12 mpg. but i drive it hard.
Old Nov 2, 2005 | 07:32 PM
jean_pierre84's Avatar
G - 55 AMG, E 320 Coupe Sportline, C 230 kompressor
what difference this sensor makes? the car perfomance changes??? excuse my ignorance please
Old Nov 2, 2005 | 10:12 PM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
Jean - you have asked a very important and valid question. I'm at AAPEX this week but will be able to research the difference in ceramics used. From memory - I do not believe that the Ford and MB sensors use the same thimble body.
If cost is the issue - I strongly suggest using the Bosch Universal Sensor applicable to the MB model.
Old Nov 3, 2005 | 01:32 AM
NorCal124's Avatar
W124
12mpg, OMG! I don't know how you can live with that.
kjb55: I believe the univ. specifically for the MB is only 20 bucks cheaper than the 160 an OEM one costs, I know because I sell auto parts.
Old Nov 3, 2005 | 02:01 AM
CDP's Avatar
CDP
W124's
I'll probably tackle this O2 sensor replacement this weekend since I'm tired of paying 45 bucks a week on gas even when I don't drive that hard most of the time. Gotta cruise to show off the bling bling.
Old Nov 3, 2005 | 08:54 AM
Kestas's Avatar
I believe many of the different part numbers for (Bosch) O2 sensors are simply because of the different pigtail connectors. We know there should be differences among the 1-, 2-, 3-, and 4-wire designs. I also believe many of these different sensors share the same sensor (body and sensing element).
What I'd like to know, is there a source, like a Bosch technical catalog, that can tell us which O2 sensors have the same sensor design? This way we can choose the cheapest sensor to splice into the existing connector. In addition, we could then figure out which connector to buy, since the '90 Mustang 302 connector is not sold anymore.
Old Nov 3, 2005 | 11:42 AM
ashman's Avatar
2004 C240, 2015 GL350 Bluetec
hehe I've seen you drive chris... I don't think you can cruise... hehehe LOL
I think your right foot is made of lead.
Alon
Old Nov 3, 2005 | 03:53 PM
CDP's Avatar
CDP
W124's
lol. Please don't count that time I was hauling *** off the off ramp to meet up with you.
I've taken it easy lately on the car, not that much of driving it hard anymore. Especially since I have no more brakes in the front. lol
Also, I'm going to make a visit to Kragen later to see how much they can give me that Bosch Sensor for. Thanks for posting the P/N chris.
Old Nov 3, 2005 | 06:32 PM
NorCal124's Avatar
W124
No worries buddy, I'll let you know if I pick up any miles, but you seriously need to start doing some of your own work. It's both fun as hell and saves you a bundle.
Old Nov 3, 2005 | 07:12 PM
CDP's Avatar
CDP
W124's
lol. You swear like I'm going to pay someone else to install this for me.
By the way, 48 bucks at the local Kragen, but I'm buying it this weekend. Supposely you get a 10 dollar gas card with purchase. haha Can you confirm chris?
Old Nov 3, 2005 | 10:04 PM
NorCal124's Avatar
W124
Yeah but those things take forever to get in the mail. I guess its worth the wait.
Old Nov 6, 2005 | 06:44 PM
CDP's Avatar
CDP
W124's
So I replaced the O2 Sensor on friday, doesn't seem like my gas mileage has improved.
I'm wondering, could there be any other contributing factors that could lead to bad gas mileage?
Old Aug 22, 2006 | 02:30 PM
flyaway718's Avatar
E320 Year 2000 4Matic Oxygen Sensor o2
I need to replace the 2 rear O2 Sensors. Does anyone know if this is the right part?
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Old Aug 22, 2006 | 07:38 PM
yhliem's Avatar
See sig
Just a thought, but rather than replacing the connectors on the O2 sensor, wouldn';t make more sense to make an adapter so that you don't have to go through the whole process again the next time you might need to replace your o2 sensor?
Old Aug 22, 2006 | 09:22 PM
Kestas's Avatar
That's what I was suggesting in my post above (Post #15). Some time ago, someone figured out which cheaper replacement is the same as the Mercedes O2 sensor. It was in the following dead link:
http://hsb.baylor.edu/html/easley/mercedes/welcome.html
That particular sensor happened to be one from a 90 Mustang 302, and the proper adaptor was identified by part number, allowing anyone to go to the Ford dealer and buy the adaptor for $9.06. But alas, the dealer doesn't supply this adaptor anymore. It's not on their books.
If I had access to a good Bosch O2 sensor catalog, I could perhaps figure out which applications use the same O2 sensor and find which manufacturer sells a connector to match. I tried getting information from the internet, but there's just not enough detail.
The Mustang sensor fit a lot of older models, but it didn't fit my model.
Old Oct 13, 2007 | 12:22 PM
floodkid's Avatar
1986 300E
Thanks alot Nor
just changed my O2 sensor
ended up buying the right one ($140) but the step by step still helped things go alot smoother.
Thanks again
