Rev counter
Old Nov 4, 2005 | 05:27 PM
kencor's Avatar
Rev counter
The rev counter on my '94 E220T doesn't work. When the engine is switched off the needle flicks up slightly. Sometimes when driving the needle flickers then stops. Has anyone and ideas about the problem, or a solution?
Old Nov 5, 2005 | 01:54 PM
jean_pierre84's Avatar
G - 55 AMG, E 320 Coupe Sportline, C 230 kompressor
there's a sensor that counts the revolutions wich is wired to the gauge. my best guess is that the sensor just died you may have to change it, its no big deal. if the engine runs fine there should be no problem.
Old Nov 7, 2005 | 07:02 AM
Luokyio's Avatar
W202 C 220 Elegance
Over voltage fuse blown...
Old Nov 7, 2005 | 03:25 PM
ashman's Avatar
2004 C240, 2015 GL350 Bluetec
It could be a bad solder joint too. I have heard of it needing to be resoldered.
