Windows On '87 300td Will Not Go Down!!
The windows on my '87 300TD will not go down. I have replaced the lock-out switch and the fuses, nothing seems to help. I am desperate!!Any suggestions?
1992 300e
What about relays? I am not sure if they have one for the power windows
If they Do and it's not a stand alone relay, it might be wired into the sunroof relay, I have seen this on another car before, might not help here though. Good luck!!
HTH,
Ron
HTH,
Ron
Mercedes-Benz w124
lock out switch? so im assuming its the rear windows then. have you tried another switch.. it may be the switch alone. just try and use it with one that does work. that and i think there is a relay also
HTH,
Ron
HTH,
Ron
Somewhat typical for window motors to fail.
Motor/regulators available on eBay.
I've replaced two on my '88. There were no problems other than bad motor, i.e. checking fuses, etc. is likely wishful thinking.
