Water Pump Replacement on a 260E
Old Nov 12, 2005 | 02:13 PM
mburton's Avatar
Unhappy Water Pump Replacement on a 260E
Water pump is noisey and leaking coolant. I pulled off the radiator, shroud, aircleaner, fan, and belt, but I can't see all the nuts that hold the pump in place, and for the 3 that I can see (top front, top rear and lower rear) the only one I can access the the top front. How do I access the other nuts to remove the pump. /mb
Old Nov 12, 2005 | 06:49 PM
ashman's Avatar
2004 C240, 2015 GL350 Bluetec
try http://mb.braingears.com
Go to the w124 section, I think it is on disc one and look for the waterpump replacement procedure for your model
Old Nov 13, 2005 | 01:35 PM
mburton's Avatar
260E Water Pump Replacement
Thanks, I did go to the site, but couldn't find where they put water pump info. Later yesterday I talked with a mechanic that said I needed to remove the belt tensioner. Do you know where I can find a diagram of the tensioner and it's retainers? /mb
