Window Troubles...PLEASE HELP
Old Nov 25, 2005 | 11:38 AM
POINTCONCEPCION's Avatar
HI everyone, this is my first post, so i don't know if this question has been covered. I have a 91 300ce and my front driver side window will go down but not all the way up. It will go up but when it gets to about an inch from the top it starts making a loud knocking sound. If i force it all the way up it won't go back down, it wants to but doesn't and makes that same sound. I was thinking it might be the guide jaw. ANy help would be much appreciated Thanks
Brian
Old Dec 5, 2005 | 01:23 PM
jean_pierre84's Avatar
G - 55 AMG, E 320 Coupe Sportline, C 230 kompressor
hi there. i had the same problem a few months ago, and let me tell you the solution is not cheap at all. what you have to do is go to the dealer and ask for a motor window and a zipper if that also broken, both are around $600. good luck with that
Old Dec 5, 2005 | 10:40 PM
349 BHP's Avatar
Mercedes E320 , Lexus IS350
..... Motor .... zipper ..?? $600??
Get your window regulator replaced. Shouldn't be more than $150. I had mine replaced at least 4-5 times, I've lost count.
