Fuel Level Sending Unit
It kind of scares me when I'm not really sure how much gas I have left...
Thanks,
-Andy
i took it out opend it. there are 3 tense's wires.
2 for the float to indicate the fuel level for the meter, and one for
the the lamp.
at my sending unit one of the wires (the level wire) was cut.
i took a soldring iron and a small pincette and solder the wire to it place.
its a 20 min. job. its about 4 month's working great likE a new one.
To check the fuel meter
1) take out the connector from the fuel sender. - at acc. meter should be
at zereo point
2) take a short wire and short the positive common wire (check the positive
wire with a voltmeter with one end of the probs to the ground, it should be
12v , acc on)
to one of the two pins on the sending unit connector. if it is the lamp wire
then the lamp at your fuel meter will light.
place the wire to other pin of the connector the fuel meter should jump
to max.
GOOD LUCK!
