Suspension Question
This might be a stupid question but can said loosness be detected while car is on the ground or I have to jack it up? Should I just pull on the shock back and forth?
Thanks again.
goes . i check for leaks when the car was on lift, and there is no leaks.
i think also that the problem is a bad accumulator.(there is only one accumulator)
what is the accumulator part nr.? and where can i buy it?
Still wondering if anyone out there can confirm if they are indeed the source of the clunking noise. The shocks have no leaks and should be good at only 60,000 miles.
