Check engine light – Code 4 (on plug itself – red light on diag. mod.) & Pin 14 CC/ET
The diagnostic light on the modular plug under the hood on the passenger side of the engine compartment flashed “4” and then I put the home made code reader in pin “8” and got 1 flash…no fault found. When I put it in pin “14” it flashed “11” times. I did this twice to insure the code.
The “11” indicates --
“11 Closed throttle recognition signal to engine control module (HFM-SFI or Left LH-SFI) Fuel safety shut-off to engine control module (HFM-SFI or left or right LH-SFI)”
I believe that my engine contains the HFM-SFI
1995 E320 4dr Sedan W124 6 cyl auto., 90,000 mi.
What in the world does this mean?
Is it serious?
How do I fix it?
I’ve been told that the O2 sensor usually goes bad.
Should I check the code on any of the other Pins?
I’ve left the code stored so that I can check other pins if necessary.
Thanks for your help
While the code reader is nice, sometimes it'll send you on a ghost chase...BTDT with the dreaded 'limp mode' the 500Es typically get when the electronics get old and brittle.
Post your question also over at MercedesShop.com in the Tech forum....good techs there usually can help.
