Lug Bolts
Old Dec 21, 2005 | 12:44 PM
HeadTurning400E's Avatar
400E (177k)
Lug Bolts
Hello,
Could someone please let me know the lug bolt dimensions for their stock bolts. My Zenetti's use a different bolt than OEM and during my move this summer I somehow misplaced the bolts and need to put my winter tires on. Also if someone would happen to know a good place to get these bolts as opposed to the stealership I would appreciate it.
-Al
Old Dec 21, 2005 | 01:29 PM
YNVDIZW124's Avatar
lots of cars
Ok since i had different wheels almost every two weeks for the past 4 months on my car im pretty sure i can help you on this one. I also had zenetti's and the oem bolts are M12x1.5 29mm or 27mm for the back. Also they have a ball seat not a cone seat. The only problems with bolt size is in the back because they may hit the emergency brakes. Newer mercedes wheels also use a 39mm long bolt but you can tell fast the ones you need. I got my bolts from ezaccessory.com.
Old Dec 22, 2005 | 03:13 PM
lkchris's Avatar
'10 CL550, '12 GL550
Get wheel bolts for OEM wheels at autohausaz.com
Old Jan 10, 2006 | 05:12 PM
400E (177k)
Does anyone have the part numbers for a lug bolt for the original wheel? I tried to order the lug bolts suggested and the only thing they asked for is part #.
