help me pls
Old Dec 26, 2005 | 04:47 PM
e320newbie's Avatar
91' 300e // 99 300e TD // 00' ML55 AMG
help me pls
300e havin some starting troubles.... once i finally get her goin it laggs power like crazy , all the plugs are workin tested those.... once car warms up it starts and idles niceley. when applying gass it laggs a fair bit and the exaust is lookin thick white and its burning rich for sure,,,, does anyone have any idea on what that is all about? fuel pump, filter... wtf could it be? doesnt seem to be anything huge .,... just takes forever to turn over and takes a while to run sounding smooth.... ok thanks guys merry X mas
Old Dec 27, 2005 | 01:11 PM
E320BENZ's Avatar
I would start at the fuel pump and filter and go from there. see how it runs after that.
Old Dec 28, 2005 | 01:57 AM
e320newbie's Avatar
thank you sir
Old Dec 28, 2005 | 08:00 AM
E320BENZ's Avatar
have you taken your car out on the autocross yet.... maybe the last owner did'nt run the car that hard... clean out those fuel injectors u enjoying ur new ride?
Old Dec 29, 2005 | 04:34 AM
e320newbie's Avatar
that 300e is gettin sold... but ill enjoy the amg! audio and visual goin in next week!!! ive been wayyyy 2 patient! oh well.. good work takes time to access, later ill clean out those injectors and try that pump and filter... will the one from my 94 E320 work on the old 86? it would be nice but if not then i gotta get one soon.. ok later yall
Old Dec 29, 2005 | 10:01 PM
Kestas's Avatar
95 E320 Cabriolet, 108K
To me thick white exhaust would signify a coolant leak into the combustion chamber via blown head gasket. When you checked the plugs did they appear suspiciously clean? How is the coolant level? You may want to mark the level where it is now and check for coolant loss. Sniff the exhaust.... this may give a clue.
Old Dec 30, 2005 | 01:46 AM
e320newbie's Avatar
what should the exaust smell like if is head gasket?
Old Dec 30, 2005 | 11:03 AM
Kestas's Avatar
It should smell sweet - like coolant.
Old Dec 31, 2005 | 01:11 AM
Qamar's Avatar
E 240 model 1999 Station wagon
Check out the Fuel pump relay. If the car starts and the moment you give gas and it starts showing the power loss then there are only two things to consider first:
1) Change the fuel filter.
2) Fuel relay which is near to the fuse box. Open it up and inpect it thoroughly. In my car the relay looked very nice but eventually when i replaced it so now there is no loss of power in my car.
Best of luck
Old Dec 31, 2005 | 01:16 AM
Qamar's Avatar
I am sorry . i posted the reply in the wrong tread....
