w124 heads
Old Jan 14, 2006 | 02:14 PM
gbaganz's Avatar
1986 300E, Lexus ES300
w124 heads
i know that the early 124s have the SOHC and that the newer ones have a DOHC 24 valve, so my question is are the heads interchangeable?? if so what are some things to look out for? it would suck if i mashed some valves. but i would love the increase in HP
Old Jan 14, 2006 | 06:02 PM
lkchris's Avatar
'10 CL550, '12 GL550
Nope
Later ones have variable cam timing, etc.
Distributorless ignition.
Etc Etc
Old Jan 14, 2006 | 06:56 PM
McBear's Avatar
500E's
From every source I can find they are NOT interchangable. I talked at length with Pat from PGAutos which tear these things apart daily and he says absolutely not. I wanted the same thing.
Old Jan 15, 2006 | 01:12 AM
neanderthal's Avatar
from what i can recall as an apprentice motor mechanic at the mercedes benz agent in a far off place in a long distant time, the bottom ends (short block) are the same with minor differences, especially so with the early 3.0 liter version.
from my recollection the only real differences between the short blocks was something to do with the chain guide or tensioner. and oil squirters under the pistons or something like that. other than that they were fundamentally the same.
that was over ten years ago.
will the heads interchange? i cannot say, although if i had an early 104 head lying around and lots of free time, id give it a shot; based on my recollections.
Old Jan 15, 2006 | 09:56 AM
lkchris's Avatar
Curious what your plan for an ignition system, i.e. distrubutor, would be.
Old Jan 15, 2006 | 12:33 PM
gbaganz's Avatar
if it would work i was going to use a stand alone like megasquirt and msd there would need to be alot of electical changes made
no more mechanical fuel pump
i might get a 104 and do a swap
Old Jan 15, 2006 | 02:15 PM
NorCal124's Avatar
W124
You're better off getting a car with a M104 already in it. You'll spend much less.
