Radio Code
Old Jan 21, 2006 | 06:44 PM
Brian McL's Avatar
Radio Code
I tried to enter the code on my radio (with a low battery) and after 3 tries it said WAIT....how long do I have to WAIT before I can re-enter the code? I have a new battery so there shouldn't be a problem with low voltage.
Old Jan 21, 2006 | 08:11 PM
Techno Duck's Avatar
1994 MB E320, 1988 Porsche 951
The Owner's manual says after 3 tries, a 10 minute wait with the power on will allow you to re-enter the 4 digit code, if you screw up again, you will need to wait 24 hours with the power on. Please look at my earlier posts on radio codes.
Old Jan 22, 2006 | 11:24 AM
Brian McL's Avatar
Great...that makes sense. I haven't had power to it for 10 minutes...the battery is dead.
Old Jan 22, 2006 | 11:26 PM
ebennz's Avatar
your/a local dealer can provide you the code thru a vmi check
Old Jan 24, 2006 | 12:54 PM
Brian McL's Avatar
When I put in the code that was supplied by the dealer...it goes back to CODE...I entere the numbers again...it goes back to CODE...I enter the number AGAIN....then it says WAIT. Now I need to wait 24 hrs...what a pain!!! Is it possible to check the code with just the serial number?? I think the radio may have beed changed and I have the wrong code.
Old Jan 25, 2006 | 02:22 PM
Brain, go to another dealer and see if he gives you the same code. I had the same problem and burnt out the radio taking a short cut. Please see my earlier posts.
