Window problem
Old Feb 5, 2006 | 10:37 PM
NorCal124's Avatar
W124
Window problem
My rear driver's side window isn't working. I moved around the switches and they all work. Before I go scavenging for a window motor what else should look for? I checked out the fuses in the engine compartment and all are fine. Thanks in advance.
Old Feb 5, 2006 | 10:59 PM
Nick_M_51988's Avatar
1992 400E (86 300E, 98 S420) - Retired
my rear drivers side door has a short in the wiring. to fix it i have to open it up all the way and slam it shut.
sounds ghetto, but it works for me.
at least you dont have to spend lots of money on a motor and not ending up needing it.
Old Feb 5, 2006 | 11:04 PM
Bigdot's Avatar
some
lol
Old Feb 9, 2006 | 11:28 PM
pifcat2's Avatar
300TE / 300E / 300CE
I found the wire to connector loose on the motor. Soldered them and they were ok...
Old Feb 10, 2006 | 01:58 AM
HA!
i bet when you tried my method it worked.
ha just kidding.
thats probally whats wrong with mine, how did u get the panels off? i havent even really looked at mine.
Old Feb 10, 2006 | 02:47 AM
pifcat2's Avatar
remove the trim at the lock, mirror corner panel, pull off are rest handle cover, unbolt handle attachment to door, unhook the lock rod, unscrew and remove the seat switch, then pull UP or you will break the plastic hooks...
