slow transmission
Old Feb 11, 2006 | 04:16 PM
crr1612's Avatar
Mercedes benz 1991 300ce(RIP), now an 89 300ce
slow transmission
i listed this under another thread at an earlier time but decided to give it it's own.
my 300ce takes its time in between shifting into drive or reverse and is a little slow just shifting between gears in drive. does anyone else have this problem?
Old Feb 11, 2006 | 09:18 PM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
Have you ever had your tranny "FLUSHED" ?
Old Feb 12, 2006 | 02:01 PM
ebennz's Avatar
well, have you??
or ever done the tranny service-filter and fluid changed??
you can't just add sea foam snake oil, fuel injector cleaner/techron and expect your car to properly and correctly fixed.
you have to do the maint when it is scheduled-not 2 years ago.
if you won't listen to what people and your maintenance book tell you and take care of your merc, people will stop wasting their time helping you.
i'm not trying to be an "adam henry", BUT a mercedes is NOT a cheap car to own, it must be serviced.
why do you think some mb's go several hundred thousand miles???
someone pays the price!
if you can't properly service one you shouldn't have one.
a lot of your problems you bring up are because you car just needs to be serviced by a "REAL" mb technician at the stealer or good independent shop.
your car requires premium gas too.
Old Feb 12, 2006 | 05:14 PM
crr1612's Avatar
im running premium gas. and i have had my atf changed, less than 1000 miles ago.
Old Feb 12, 2006 | 07:26 PM
Brian McL's Avatar
same
...the next thing is that it will not go into reverse.....then the tranny needs to be re-built, unless you decide you don't need reverse. Same thing happened to me. Cost me over $2000. Works great now!!
Old Feb 12, 2006 | 09:41 PM
crr1612's Avatar
i hope not. reverse seems to be working fine. the only reason im really curious to see if anyone else has teh problem of the car taking its time shifting into drive or reverse is because i have had a few snow storms recently. i found it nearly impossible to rock the car out of the snow, because by the time id the car would shift into reverse i would have already lost my momentum...same thing with drive. i read this on consumer guides, and was curious to see fi anyone else was experiencing the problem. thanks again
Automatic transmission: The transmission may delay shifting into Drive or Reverse, and may be corrected by installing reformulated Mercedes-Benz transmission fluid.
Old Feb 13, 2006 | 11:14 AM
C43AMG's Avatar
Veteran: Army
Having it "changed" is one thing , having it flushed is another.When its "changed" the pan is dropped and the filter changed also.The problem lies in the MOST ( more than half ) of the fluid is still in the torque converter.When the transmission is "flushed" ALL the fluid and deposits are removed and replaced with new on a 1 to 1 basis.There is a HUGE difference between the two procedures.I have this done on all my vehicles every 30k and notice the difference.
Old Feb 13, 2006 | 11:19 AM
C43AMG's Avatar
Veteran: Army
Originally Posted by ebennz
well, have you??
or ever done the tranny service-filter and fluid changed?.
As a matter of fact genius , I have.Why don't try reading other peoples posts before climbing out the hills of Virginia with a dumbass comment like the one you posted?You bring alot to the table here with a comment like that - 5 yrs. and 250 posts and you're gonna post some garbage like that?
Old Feb 14, 2006 | 08:53 PM
ebennz's Avatar
hey genius!
my post using your quote was NOT directed at you c43, it was for crr.
re-read.
i was agreeing with you.
also einstein, i live in WEST Virginia. good weed??
i'm not a post ***** and my dik size isn't measured by my number of posts.
if you were half as smart as you think you are, you'd realize this isn't the only mercedes site.
i've been around a hell of alot longer than you gonad
Old Feb 16, 2006 | 08:28 AM
C43AMG's Avatar
Veteran: Army
Virginia ,WEST Virginia, it's all the same DNA.
Old Feb 16, 2006 | 10:22 AM
ebennz's Avatar
you just can't admit you mis-read my post...maybe if you grow up and leave home???
Old Feb 16, 2006 | 10:26 AM
C43AMG's Avatar
Veteran: Army
keep ya momma out of the states, we'll keep the states out of ya momma!!
How about you learn the proper use of the "QUOTE" button Cletus?
