Is this possible?
Old Feb 21, 2006 | 06:50 PM
PAOLO JR's Avatar
Is this possible?
What engine and can be Installed In my 1989 300ce other than the org 3.0.Im looking for some thing with more power to It, Can an engine from a 300sl fit,and would It make a diff?
Any suggestion"s as to what I can play with ?
Last edited by PAOLO JR; Feb 21, 2006 at 06:51 PM. Reason: I for got some thing Important
Old Feb 21, 2006 | 09:11 PM
Bigdot's Avatar
some
your best bet would be to put a 400E engine in it, or a E420 engine, i dont think a 500E will fit.
mark
Old Feb 21, 2006 | 09:31 PM
CDP's Avatar
CDP
W124's
put a C36 engine.
Old Feb 21, 2006 | 09:48 PM
AMG_Fred's Avatar
Mercedes-Benz w124
w210 e55 DO IT!!
Old Feb 22, 2006 | 05:55 AM
cap'n jasper's Avatar
W124
Anything is possible but unless you want an engineering project the best way is to sell it and buy a 500E.
Old Feb 22, 2006 | 11:02 AM
neanderthal's Avatar
mark
400E vs 500E engine. both M119,...
(essentially) same block and heads. slightly different intakes. should fit the same
you can make your own 500E by using the 5 liter M119 engine from an R129 or W140. (power wont be the same as the genuine thing has more.) but you probably wont be able to duplicate some of the bracing and reinforcement that porsche designed into the 500E. brakes and suspension can be lifted wholesale from a donor car or your friendly mercedes dealer.
Old Feb 22, 2006 | 02:12 PM
Bigdot's Avatar
some
but then why did they have to cut and elongate the engine bay?
mark
Old Feb 22, 2006 | 04:19 PM
troy.michaud's Avatar
I believe any structural changes made by Porsche were made for strength -
The differences between the E420/400E 124 m119 and the 500E M119 is Intake, and I think stroke (different crank), and of course different cams.
Between the 500SL M119 and 500E, I have heard only the intake is different.
Anyone have any more specific info?
Old Feb 23, 2006 | 12:20 AM
NorCal124's Avatar
W124
If you can afford to have a 400E/E420 engine placed in a 300E coupe, then you probably should invest in a car with that motor in it already. If you have the technical no how and skill to do the swap, then you're probably smart enough to realize you should just buy a 400E/E420.
Old Feb 23, 2006 | 09:36 AM
I agree with the above, with the exception that there was no E420/400E or 500E coupe.
So if your goal is for an m119 powered coupe, guess you would have to make it
Old Feb 23, 2006 | 09:46 AM
Chappy's Avatar
AMG
Virtually anything is possible, given an unlimited checkbook. An M120 V12 has been shoehorned into a W124 previously.
