Please Help! Running badly!
Fri night I noticed that upon decelaration there was a new slight vibration. Well it has gotten progressivly worse and is now accompanied by harsh idle and no acceleration power and a slight rubber burning smell comming from engine compartment. I dont think its the trans as it will run rough a vibrate when stoped and in park. Has NO power under acceleration and will hardly get out of its own way. The only thing I have done is remove the wrong application Autolite spark plugs the PO installed and put in the correct Bosch Supers F8DC4. This problem began Fri night and I installed the plugs Sat morn. so I dont know if that has anything to do with it or not. I anyone has had Any similar problems, Please help as we depend on this car to get to work.
Adam
and that the spark plug boots are firmly affixed tot he spark plugs
and that the wires arent being burnt by the exhaust manifold.
check for blockages in the intake tract
run some fuel injector cleaner
take of the distributor cover and see what condition the rotor is in. also check the contacts.
any number of things can cause a car to start to run badly. the first thing you always do is cover the basic maintenance (oil change and tune-up) parts; oils, plugs, wires, filters, rotor(s), cap. this will normally sort out whatever your problem is.
from there it gets expensive.
. Thanks
Triggerman
miles now?
how long have you owned it?
have you ever changed ALL of your fuses?
it's VERY CHEAP insurance.
exactly what maintenance stuff have you had done and by whom-indy or mb tech?
does car still have original main engine wiring harness?
Triggerman
With your mileage you probably still have the original harness....and it probably is garbage.
Mine is acting exactly like has been described. Only acts up sometimes and sometimes it feels like a new E55 (well, thats pushing it!). I think I will not get an appointment at the shop tomorrow.
Thanks very much
Triggerman
the first fuse to go will be the one that controls tach, temp and fuel gauges.
they corrode and deteriorate. they only cost about .18 cents each.
change them all
http://www.mercedesshop.com/shopforu...earchid=647183
This should be about 90% of my recent problems, but they said yes I do need a harness. I have called 6 different MB dealers in my region and recieved the exact same price from all of them, $1010.
If anyone knows of a dealership that will work with you on price, or an aftermarket harness that exists, Please Please let me know, M104.092 engine (not to proud to beg).Yawl go out and check your dampener if you havent!
Thanks for all the help on this guys
Triggerman
as for the harness, check with some of the parts vendors on various mercedes forums
Thanks for the help guys.
Triggerman
http://www.autopartsworld.com/new/pr...-420&x=92&y=12
OH well
Triggerman
