Hydraulic hose...300te...rear suspension
The hose that comes out of the pump...it has these plastic inserts in it...many of them...anyone know what they do? What if they weren't there? What if the hose were the wrong diameter and the pieces "floated" in the hose, rather than a tight fit?
Nope...if you were to cut open the hose from the pump, located in the engine compartment...there are many of these plastic "bullets" inside...about 1" long... I wonder what they do? Possibly reduce the pulses sent out by the pump?
99 ML 320, 97 Porsche 993 C2S, 92 300E
Could you post a photo? Also are you talking about the low pressure return hose, held in place by a clamp or the high pressure hose that has crimped fittings and screws on.
I'd take the hose to a place that makes hydraulic hoses. They might be able to make you one, using your existing fittings or at least tell you what that plastic insert is for.
I've changed the low pressure hoses because they seep with time and I know they have no such inserts.
