A few annoying problems
2) Every once and awhile my radio antenna stows itself for no reason. The radio will be on and it will just go down, you have to turn the radio off and back on and it will come up for the remainder of the trip. Anyone had this happen?
BTW,my engine wiring harness DOES need replaced (just offering this info as this seems to effect Everything on these cars
that's how it works...i guess an attempt to not lock keys in car[?]
i can't help you on the antenna, sorry
replace all your ceramic fuses too. it'll cost $3-$5
I have the exact same problems, even with the "ant" button pressed so that it can remain in the up position it will go down regardless...
But seriously, no one knows what exactly might be happening with my antenna? Guess its a short of some kind.
But seriously, no one knows what exactly might be happening with my antenna? Guess its a short of some kind.Radio sends signal to activate antenna. Signal goes away when radio is turned off. Clearly, it also goes away if the connection between wire and antenna is interrupted.
