Things I Might Want To Update on My 420?
Old Apr 3, 2006 | 02:53 PM
Eliot's Avatar
Range Rover Classic
Making liberal use of the search function the following seem to be the most popular. Am I missing anything?
Euro Headlights with Clear Corners
Swaybars
Springs & Shocks
Larger Rims/Tires
Old Apr 3, 2006 | 04:09 PM
G Man's Avatar
1992 Mercedes-Benz 500E (W124-036), 2004 W211 E55
Your list is exactly what I was going to suggest.
Old Apr 3, 2006 | 04:12 PM
blume's Avatar
that will do! IBCJ.
Old Apr 3, 2006 | 04:17 PM
CaliE320's Avatar
88 260 E
Add
exhaust
smoked tail-lights
body kit
upgraded car audio
~Cali
Old Apr 3, 2006 | 11:04 PM
ebennz's Avatar
Swaybars
Springs & Shocks
Larger Rims/Tires
you're on the right track. you have chosen wisely-money well spent.
don't forget to add [if not done already], because this **** really fails.
proper maintanence
upper main engine wiring harness $$$
lower main engine wiring harness
radiator
power steering pump
waterpump
evaporator
misc oil leaks [front timing cover, valve covers]
peter
Old Apr 4, 2006 | 01:14 PM
Eliot's Avatar
Range Rover Classic
Originally Posted by ebennz
proper maintanence
radiator
power steering pump
waterpump
evaporator
The car has 126,000 miles, which seemed like a better buy than an E320 with 80,000. Its is hopefully over the hump in terms of maintenance, the upper and lower harness have been replaced. Believe the radiator has as well. The Evaporator is original so I'll have to watch it. Cars at the shop right now getting a look over
