Fuel Pressure Check
Old Apr 15, 2006 | 07:57 PM
Makahveli's Avatar
"88 300CE- First Year Production
Fuel Pressure Check
I need to know a couple of things:
Where exactly do you check the fuel pressure on these cars? (fuel rails? Are they under the air filter housing?)
Do I need a special fitting, as the local parts store say the domestic gauge setup will work fine.
What should the pressure be?
I have a '88 m103 engine, Thanx!
Old Apr 16, 2006 | 02:29 PM
Makahveli's Avatar
No MB Mechanics here?
Old Apr 19, 2006 | 12:39 AM
komik's Avatar
re:
the fuel pressure should be tested on the fuel distributor. There are two blanked ports. One for upper chamber pressure the other one for lower chamber pressure. Can give you specs if interested.
Vlado
Old Apr 19, 2006 | 12:41 AM
komik's Avatar
forgot to add
MB has a tool to check the pressure, however it probably will be hard to get and expensive. I made it myself.
Vlado
Old Apr 19, 2006 | 03:08 AM
Makahveli's Avatar
the local part store kept insisiting that domestic pressure testers will work fine for me, thats why I asked. But today I was just told that there a local and reasonable mechanicnearby that only works on benz's so I'm going to have him do his thing with my car.
Old Apr 19, 2006 | 01:57 PM
komik's Avatar
re:
if the fuell pressure gauge has has 8 mm thread and pitch 1mm then it will work
Vlado
