300E 2.6 Power improvements?
Old Aug 12, 2002 | 08:38 PM
Dave Binnie's Avatar
2001 amg 55 clk
Anyone have any ideas on how to improve power on a 2.6?
Old Aug 22, 2002 | 05:43 PM
V12BIGBODY's Avatar
03 S 500--94 BMW 325i--01 GSXR 1000
Yes just drive it and enjoy it. Theres not much you can do with it. Later on when you get another car but an 8cyclinder or even better a 12. I have the same car and I had to come to terms with that also.
99 ml 320
96 s 600
88 260e
71 250c
Old Aug 30, 2002 | 03:15 AM
Haasman's Avatar
'91 300E + '95 E320TE
You can change your air filter to a K&N. You can remove the resistor that retarded your spark timing, but be careful regarding fuel and pre-detonation.
Old Aug 30, 2002 | 09:26 AM
2001 amg 55 clk
great! Where is the resistor?
Old Aug 30, 2002 | 02:28 PM
Haasman's Avatar
It is usually found near the fuse box area. It is a small square black plastic piece about half the size of a match book. Often it has fallen down between the brake booster and firewall to the engine.
Old Aug 30, 2002 | 02:31 PM
V12BIGBODY's Avatar
Talking an air filter???
Wow an air filter what is he going to get 5 more horses?? Leave well enough alone. Just drive it
Old Aug 30, 2002 | 02:46 PM
Haasman's Avatar
Here is a more detailed thread for the resistor:
http://www.mercedesshop.com/shopforu...light=resistor
Old Aug 30, 2002 | 05:59 PM
Jackd's Avatar
260E , 1989 (for now)
I too have a 1989 260E and I have looked at several alternatives to increase the power.
My recommendations: Do not spent your hard earned fortune to try to do the impossible.
K & N: Nerver been, never will be a perfornce improvement item that you will be able to feel. There may be a very very slight improvement at very high RPM due to the fact that this filter has a little bit less restriction than the original filter. This is accomplished at the cost of letting much more dirt, dust, contaminants through the system.
Removing the resistor: I've tried it too. I could never feel or detect, any difference in performance.
Others have tried to improve the intake side, installed tricky exhaust system. I have never seen a performance improvement on a Mercedes with those types of modification.
A 260E is a 260E. Never been conceived to be a performance car or to be modified to become a performance car.
Unless you are ready to invest tons of cash (turbo, supercharger, stroker kit and the like), there is no simple (cheap) way of increasing performance on those cars.
JackD
