Checking Transmission Fluid>>>>
Old Apr 20, 2006 | 03:36 PM
oneill_1's Avatar
MB 300E | BMW M Coupe
I was wondering if the dipstick to check the transmission fluid is this encircled in yellow....
Old Apr 20, 2006 | 04:54 PM
Legoinsaniac's Avatar
1992 400E
Yes, that's it. Sometimes it can be kind of tricky to get off. It is locked into place, so you have to lift up on the black tab (attached to the red cap) to get it to pull up. Make sure the trannsmission is all nice and warm when you check it, and that the car is on level ground.
Old Apr 21, 2006 | 11:21 AM
mhorn's Avatar
1991 300E
anybody remember if you're supposed to check it with the engine running or warmed up and then turned off? I can never get a good read off the dipstick.
Old Apr 21, 2006 | 11:51 AM
Jackd's Avatar
260E , 1989 (for now)
Engine (and transmission) at normal operating temperature, shifter in PARK, car on a level surface.
Old Apr 21, 2006 | 03:27 PM
kwb210's Avatar
1993 300CE Sportline
engine running when checking
I beleive the engine should be idling and the car should have been driven at least 10 miles or so because the trans temp needs to be at operating temp.
