Dumb Question about a 1990 300CE-24
Does anyone know where the oil filter is?
I've got the oil drained out and cannot find the filter, I know pretty lame. I got a service manual on CD from E-bay and it does not even show the oil filter anywhere.
Also I am looking for an ignition contol unit for the car as well. I it part number 012-545-2032, I have been looking for one for about a year. I need to get me car to shift into 5th gear.
Cheers,
Jake
Cheers,
Jake
I just bought a 91 CE. The filter is were it usually is on the 124...Left Hand side of the engine near the firewall. On my car it is not a typical replacable metal screw on cartridge. It is a silver grey can with a screw on lid. You unscrew the lid and remove and replace a paper element. There is an O ring for the lid that should come with your new paper element. Taking the air cleaner off makes it easier to get to. To take the air cleaner off you DO NOT remove the nuts on the top of the air cleaner. The entire plastic thing is held to the intake manifold with two nuts and a bolt. One is near the thermostat housing, one is near the firewall by the valve cover and the bolt is on the left hand side of the air cleaner...it is kind of underneath the air cleaner and hard to see. After you take these off you disconnect the intake hose and the air cleaner will lift off...it is a snug fit around the throttle body or whatever they call it on a mercedes so you have to pull up with some force....good luck!
Did mine today. There must be some special Mercedes wrench that fits over the ribs in the lid that probably makes it easy to get the top off. I used a rubber strap wrench and tapped gently on the lid with a screwdriver and it loosened.
I did find it in my CD service manual section 18-0020. 18-1100 shows a detailed explosion drawing of the whole filter and housing
300CE-24
Originally Posted by ashman
in other parts of the world the 300ce did come with a 5th gear as far as I know.
Just for a bit of trivia,i was told by the head mechanic at the main benz dealer here in Perth, that the 300ce-24 was the first car to be offered with a 5 speed auto,in the world.I found that hard to believe,but i think it's true.
