Turn signal issues
I search the W124 boards for blinker or turn signal issues, and was unable to find anything that remotely describes the issue I'm facing.
For the funny folks, I did check for blinker fluid
The issue is as follows with my 1994 E320:
When I turn my car on, I drive off, and turn signals work fine. Usually after using the turn signal stalk a few times, for turning or changing lanes, the turn signals stop working. No light on dash, and no blinker sound, nothing. Both sides, the same. If I move stalk down to turn left, or move stalk up to turn right, the turn signal system is dead.
Interesting thing is that after a while it comes back, and turn signal system works again. And eventually stops working. So it goes off an on like that, between working and not working.
I own an Audi, where there is a known issue with the turn signal relay, when it goes bad, it basically makes the turn signal behave similarly as described. However, with the Benz, I have not checked if the hazards work when the turn signals are not.
Has anyone experienced this issue? I am ready to bring it to the dealership for troubleshooting, however if I know what needs to be done, I can simply do the work myself, depending on difficulty level.
Thanks for any assistance.
Hope it helps.
Hope it helps.
man, it's answers like this that make car forums worthwhile...
The issue appeared again, and I tried the horn, which both seem to be tied to fuse number 6, however turn signals did not work, yet the horn was fine.
Must continue to check. Probably going to the dealer to get it looked at. No turn signals is a dangerous thing.
Has anyone experienced the similar thing?
I think your fault is probably a short circuit inside the combination switch on the steering column, the only way you can check this is by fitting another switch which is known to work properly.
Cheers, Geo.
Well, I was unable to find any crack on the soldering as Arnie had mentioned. Decided to take the car to the dealership for a quick look. They did replace a relay (part number 201-821-01-47). Unsure exactly where this relay was replaced at. Must check the fuse box again.
So far all is working, given it was a $161 part.
Smokie
https://mbworld.org/forums/e-class-w...ge-wipers.html
I'm a newbie here.
I drive a 1993 W124 E200 diesel. Today on my way to work, I noticed my turn signals had stopped working. I checked the hazards, wipers headlight flasher/dimmer they all work fine. Only the turn signals aren't working. I drove it 2 days ago and everything was fine.
Is it the combination relay or some other issue?
Hoping your collective wisdom would help me out here.
Thank you!
