Electric fan can't make up it's mind!
Old Jul 5, 2006 | 01:56 PM
Legoinsaniac's Avatar
1992 400E
Instead of coming on and staying on, and then shutting off when the engine temperature has sufficiently cooled, my electric fan will click on and off repeatedly, almost like it can't decide if it should stay on or not. This is annoying because you can hear it clicking on and off from inside the car. Anyone know what could be causing this?
Old Jul 6, 2006 | 03:00 PM
kwb210's Avatar
1993 300CE Sportline
how long does it run?
What is the time period that it runs? Mine clicks on and cycles for only 15-30 seconds and cycles off. I'm driving in temps not higher than about 80 degrees.
kurt
Old Jul 6, 2006 | 09:29 PM
1992 400E
Nope, mine is totally on the fritz. It will come on and shut off in 1-2 second intervals, and sometimes even faster! This doesn't happen all the time, but it does happen at any temperature, even when the car is still cold. Besides this, the car's cooling system is totally normal. It doesn't overheat, and will maintain the normal temperature. Strange, huh?
