Car hesitates when given gas
My previous car, a SAAB which also uses the Bosch engine management system, had similar problem and very difficult starting when cold. My mechanic told me it was a loosen plug for the Negative Temperature Coefficient sensor (don't know what it is:p). The problem was fixed by re-plugging the sensor.
Good Luck.
what you described in the SAAB is pretty much the same for the Mercedes. There are some temperature sensors to control the cold start periode which might cause the problem if defect or connections being open. You'll find those temperature sensors on the top right side along the engine block. You can check the plugs being off. You can can also check the resistance of the sensors against ground. If they are short circiuted (no resistance to ground, they need to replaced and the problem might be solved. Sometimes (especially for the twinsensor at the far end of the motor block) the wires are broken and there is no function anymore.
Good luck finding the devil, but as you understand it's hard to do remote diagnosis'.
It's not my car encountering the problem. Anyway, your advice is very useful and I learn something from you.
Do you know where the fuel pump relay is? My car is W124 3.0l in line six. I want to check that relay. Thanks.
Hi bamberger_1,
It should be behind the plastics behind the battery There you will find i think 3 relays where one is the fuelpump.
Do you know where the fuel pump relay is? My car is W124 3.0l in line six. I want to check that relay. Thanks. [/B][/QUOTE]
The fuel pump relay sits behind the battery and a (flimmsy) plastic cover. As the other poster said, you'll find 2 relays (black blocks) one is A/C (KLIMA) the other is the fuel pump relay. But unfortunately there is not much to repair or check, since it's a complex electronic board only.
