Resetting the ECM - Shortcut?
2006 E500 AMG PKG/2010 Camaro SS/RS - 2007 F-150 - 2007 Suburban
Is there a way to reset or "flash" the ECM (engine computer) without the diagnostic tool,or whatever it is my mechanic uses?
lots of cars
My understanding is that you just unplug the positive terminal of the battery for at least 30 minutes. That got my check engine light to turn off when I did it. I'm not sure if that is what you're asking though.
'01 W210 E320 CDI
It's also my understanding that disconnecting the battery will reset the ECU. I usually do this after doing work on the ignition like new sparkplugs or cables etc. You can really notice the ECU is self-learning cuz after a reset the cars' trans is almost as nervous in "E" as is is in "S" and after a while it settles down to your normal more relaxed driving style...
'01 W210 E320 CDI
Originally Posted by YNVDIZW124
I've been told if you disconnect the positive terminal and turn the ignition key on and then tap the terminal 3-4 times.
Mercedes benz 1991 300ce(RIP), now an 89 300ce
what are "E" and "S" ?
lots of cars
My 230E had that and i always had in in E, In S i raced the ***** out that 4cyl engine...I loved that car but because i live in california it was impossible to get it smogged, i had to find and pay a "premium" to get it passed...I eventually took most of the parts off and put them on a 190e and the rest on another 300e..
