My mercs shaking ?
Old Aug 18, 2006 | 10:00 AM
vix's Avatar
vix
mercedes E220 (w124)
My mercs shaking ?
A few days ago i got my exhaust changed.
but
now when ever i start it it shakes and a rattling sound comes from under the car. its especailly when the car iz cold or stationary. but when it becomes hot it doesn't shake as much but i still hear rattling.
could it be the exhaust pipe or its mountings or did the garage do a cheap job .
Old Aug 18, 2006 | 10:34 AM
mgw_300e's Avatar
Dora the Explorer
but
Check all the places where any pipes or manifolds are attached, there may be some loose bolts. Also check all of the hangers and make sure they're all attached properly.
My money's on the bolts though.
Old Aug 18, 2006 | 10:53 AM
vix's Avatar
vix
so you mean the bolts may be causing the to rattle and that may be shaking it?
Old Aug 18, 2006 | 10:54 AM
vix's Avatar
vix
the manifold wasn't touched it was the back bit that was changed because if i am correct the exhaust pipe is in 3 pieces?
Old Aug 18, 2006 | 11:02 AM
mgw_300e's Avatar
Dora the Explorer
The shaking part probably has something to do with the engine - motor mounts or trans mount maybe. When those wear out they stop separating engine vibration from the chassis, and it feels like shaking, especially at idle. If you have this problem going on AND your exhaust has loose parts, you get a rattle from underneath your car. It could be other things that bolt on - sway bar bushings, heat shields, etc, but since you just had your exhaust done, it's probably that.
Old Aug 18, 2006 | 11:03 AM
mgw_300e's Avatar
Dora the Explorer
3 or 4, I'm not sure.
Old Aug 18, 2006 | 10:28 PM
YNVDIZW124's Avatar
lots of cars
My exhaust did that for a while when i changed the exhaust donuts..It stopped after a month..
Old Aug 19, 2006 | 11:17 AM
lkchris's Avatar
'10 CL550, '12 GL550
Check oxygen sensor connections.
Old Aug 19, 2006 | 11:23 AM
vix's Avatar
vix
would you now were the the oxygen sensor is located and is this a serious fault or expansive to fix ?
Old Aug 21, 2006 | 09:24 AM
Payson's Avatar
E500 W211 ex-E320 W124
the same happened to me
This thing you comment happened to me 10 days ago and its a very simple thing what happens. What happens to you is the new exhaust is hitting at the end with the chasis ( with the plastic part) and it will end melting it so the exhaust and the chasis get together and you wont hear anymore the shaking.
The solution is quite easy, the mechanic should do it for free, just turn a bit the exhaust so it doesnt hit any part. Is so simple.
Old Aug 21, 2006 | 11:42 AM
vix's Avatar
vix
thank u for the tip
