Help PLEASE!! Major electrical problem 94 E420
The security system will not arm when the doors are locked. There is a ticking coming from the white relay behind the fuse box. (The really long white one).
All this started after an uneventful evening ride!. I pulled into the garage and noticed that the alarm system did not engage. I turned the key on and discovered all this and the starter will not engage. 2 times in the last 2 weeks, the starter would not engage, but I simply got out locked the doors and unlocked the doors and the starter would engage. That does not work this time.
Help Please!!!!
Many Thanks,
Bill
UPDATE and additional HINT.
All the above problems still persist, but, While holding the key in the crank position (no cranking of course), I moved the steering wheel in and out with the electrical control and it passed a point where the engine cranked and started. I backed out of the garage at which point the ABA and ASR light came back on. I pulled it back into the garage and shut it off. I have not been able to crank it again. Is there a sensor in the steering column?
Thanks,
Bill
UPDATE:
I noticed that I had no brake lights. Checked the fuse and it appeared intact, but when I removed it I could see that it was not. Put a new fuse in and all is well. I now have brake lights and my car starts. My entire car was shut down for lack of brake lights. Fixed now though, all dash lights are as they should be and the security system arms as it should. Pretty cheap fix!
Bill
Help Please!!!!
Many Thanks,
Bill
Thanks,
Bill
UPDATE:
Bill
My car (how ironic) has decided not to turn over as of friday, due to a marvelous faulty 18 year old starter
I hope that's not it.
in the fuse box drivers side firewall!
Sounds like what was going on with my 95 E420! One of the fuses had a hairline break which I could hardly see! I mean just about everthing on that car quit working! So lookem over real good!
Smokie
I just recently aquired my w124 and am having some probs (engine shutdown while at speed or at a traffic light and also while radio is on) also will be checking my fuses also and buying an extra set before I head down south.
